Old 4-Sep-2014, 8:05 PM   #3
Above the Peak of the Roof in such a manner that reception will not be , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , South East , North , North West.
Install a.
CM4228HD , UHF/VHF antenna.
Aim the CM4228HD antenna at about 146 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
To discover the best reception , most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Strength Meter.
As always , the antenna aim direction and the antenna location can be adjusted for the best reception.
The Signal Strengths Are Strong.
A antenna system amplifier is not required for reception of the Victoria area Tv stations to the South East and the 1 Tv transmitter to the North.
http://www.ronard.com/909911.html. Install the 3 foot or 5 foot tripod antenna moiunt.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Home Depot has , 10 foot 6 inch length - 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe. The price is low at about 12 dollars.
To Prove Reception , connect a NEW Continues Length of RG-6 Coax to the
CM4228HD antenna and run the NEW Continues Length of Coax through a open
door or window direct to 1 Tv.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building , in the directions of reception.
The directions of reception at your location are , South East , North , , North West.
