Old 4-Sep-2014, 6:40 PM   #27
The Correct Way is to install the antenna in such a manner that if the wind or something else knocks what the antenna is mounted on and the antenna Will Not Fall on to the the utility lines.
Murphy"s Law is in full effect.
So install in such a manner that will not Fall Into or On the utility lines.
As you have discovered.
And others that come here to tvfool.
Are doing there absolute best to prove that close trees will not disrupt and block reception.
The Truth is , trees and tree leaves , plants and plant leaves , will disrupt and block reception.
