Old 4-Sep-2014, 5:23 PM   #8
So best bet is the 751 and hope for the best?
Given your family's self imposed limitations, yes.
I would have no problem installing a tripod on a new roof... Just did less than two years ago as a matter of fact. New roofing materials are less likely to be brittle than older material so I have less concern about leaks. I'd also look at a ground mounted mast or tower, or, eave brackets... any reasonable option that would get the antenna(s) clear of trees would be on the table.
