Old 4-Sep-2014, 4:51 PM   #6
gordonlw
I hear ya. So best bet is the 751 and hope for the best?
Should I use existing coax first or go ahead and run a shorter run to the main tv? Splitter would likely have to be on the outside of the house as that section has no attic access and is on slab. There is a hole to get one run in already. I could spilt it on the outside and then go into the basement for the other tvs. This would significantly cut down the cable length's from what is there now. Not sure I could use a preamp splitter b/c of lack of ac there.
Thanks again!
gordonlw is offline   Reply With Quote
