Old 4-Sep-2014, 3:05 AM   #2
Nope. It will probably make matters worse because, at 30 dB gain and with a local in your back yard, it will probably overload, especially if the signal hits that distribution amplifier.
If you want reliable reception of channels 7 & 10 out of Quincy, you need to put up a larger directional antenna pointed at them. You will also likely need to re-consider the rest of your collection of equipment depending on what you're trying to accomplish with it.
