Old 4-Sep-2014, 2:51 AM   #1
greggor
Help me choose an Antenna east of Kalamazoo MI
Hello
I would like some help to choose the right antenna(s) based on my location in Comstock TWP east of Kalamazoo.
I live in a 2 story vinyl sided home with no obstructions in any direction. My inclination is to install the antenna on the back of my home mounted outside on the roof of a first story covered porch (25' tall). This installation would block the eastern stations. There is a previously installed Direct TV dish that I hoped to just use the coax cables already there. I would be looking to receive the Kalamazoo stations (approx. 160 degree) and Grand Rapids stations (Approx. 355 Degree). I could mount higher on the peak of the roof (40') if there is a good reason to go that route, in this case I could try to get signals to the east (76 degrees).
Looking for help in deciding if one antenna and rotor or 2 antennas (one pointed to each location) be the best option (or needed) what brand/model is recommended. I would like to run the signal to a splitter to connect 4 TV’s with probably 50' of coax before the splitter. So I am also interested in whether I will need an amplifier and where to install it (at the antenna or before the splitter (the latter I would guess).
Here are two reports first is 25 foot antenna the second with a 40 foot antenna height
http://www.tvfool.com/?option=com_wr...d243d878d81cea
http://www.tvfool.com/?option=com_wr...d2435522132669
Thanks for your help
Gregg
greggor is offline   Reply With Quote
