I apologize. I just read your response teleview. I was on my phone yesterday evening and somehow missed it. Thank you very much for your detailed explanation. I absolutely appreciate your advice and will buy whatever would be deemed necessary. I just think that I maybe didn't include all pertinent information. I ONLY need to pick up WFLD from Chicago, for the Bears games. That would be the only time I would ever need to pick up that signal. The neighbor, uses DB8e, to pick up that station (including several others from Chicagoland). So I do know that antenna will pick it up. However, he also has Directv, and doesnt need that antenna to pick up local channels from Milwaukee. I was hoping, knowing that DB8e will pick up WFLD in Chicago, that it would also pick up stronger signal from backside from Milwaukee. But it seems that the hd1200 is the way to go. Although I'm curious why the focus on VHF, as there are only two stations (I believe) that are VHF from my report. PBS and an independent station. Not a big deal at all if I didn't get them. Knowing that I do not need VHF, would that change your recommendation?
Reason: Clarification
