Thread: Wfsb
Old 3-Sep-2014, 11:53 AM   #9
antennaCT
The mclapp design is one of the better DIY options. I would consider it a good general purpose antenna. For your specific application (gooing after WFSB), I would lean toward a channel cut design, optimized for peak F/B ratio.
If you are trying to avoid a store bought solution, consier building a pair of identical Yagi antenans cut for real CH-33. I just uploaded a design for one... http://forum.tvfool.com/showthread.php?t=1106
A stagger stacked pair may achive the needed forward gain together with sufficient F/B ratio.
GroundUrMaster
I just viewed your Yagi design. I know very little about them, not quite sure what to make of the info or how to build yet. I'll read up on these.
BTW Last night I covered the back of my existing antenna did a re-scan and was not able to pull in WFSB I did loose WCBS so the co channel issue should not have been a problem.
Thanks again for your assistance.
antennaCT is offline   Reply With Quote
