Old 3-Sep-2014, 10:01 AM   #3
For Maximum Reception of as many Broadcast Tv Stations/Channels that Can Be Received.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , North West , North , North East , East.
Install a , Antennas Direct , DB8e , Current UHF channels 14 thru 51 antenna.
Buy at , http://www.amazon.com.
Aim the DB8e antenna at about 340 degree magnetic compass direction.
Also install a , http://www.antennacraft.net. CS600 VHF channels 2 thru 13 antenna.
Also aim at about 340 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas , do not trust a , cell phone , tablet and etc. compass.
As a assist of the best reception most Digital Tv's have a Signal Strength Meter and some Digital Tuners also have a Signal Quality Meter.
Install a , http://www.antennacraft.net.
10G221 preamp.
Connect the DB8e antenna the the UHF connection of the 10G221 preamp.
Connect the CS600 antenna to the VHF connection of the preamp.
http://www.ronard.com/909911.html. Install the 3 foot or 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length - 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe. The price is low at about 12 dollars.
For 3 Tv's connected use a , Holland electronics , HFS-3D , 3 way splitter.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Also Know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
The Best Practice for Reliable Reception is to install antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building , in the directions of reception , North West , North , North East , East.
Tvfool is showing the reception location as having , Analog Broadcast Tv Channels and Digital Broadcast Tv Channels.
Here is the Analog Broadcast Tv Channel , http://en.wikipedia.org/wiki/WETV-LP. Channel 11.
In the Tv Setup Menu select and channel scan for Digital Broadcast Tv Channels and Analog Broadcast Tv Channels.
When Doing a Channel Scan Do Not Channel Scan for Cable Tv Channels Only.
The reason is the Tv is not connected to Cable Tv.
It is connected to a Tv antenna.
