You will probably need to keep the panels aligned in parallel and use a rotor to accurately aim the antenna. This assumes no impairments in front of the antenna such as trees, buildings, or other structures. The numbers say WFLD is receivable, but there are factors not included in those numbers.
Use a low noise, medium gain pre-amp unless you have an extensive distribution network.
