Old 2-Sep-2014, 10:42 PM   #6
Know This about Reliable Reception.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building , in the directions of reception.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is not install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The directions of reception at this location are , North West , South East.
Tvfool shows that a good antenna height above ground is 25 feet.
Install a , Antennas Direct , DB8e , antenna.
http://www.amazon.com.
Aim 1 panel of the DB8e antenna at about 121 degree magnetic compass direction.
Aim the other panel of the DB8e antenna at about 314 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antennas , do not trust a , cell phone , tablet and etc. compass.
To assist the best reception , Most Digital Tv's have a Signal Strength Meter and Some Digital Tv's also have a Signal Quality Meter.
As always , antenna aim and antenna location can be adjusted for best reception.
Here are some and not all antenna mounts.
http://www.ronard.com/909911.html. Install the , ronard , 3 foot or 5 foot tripod antenna mount.
http://www.ronard.com/712.html. Install the , Ronard(712-50-10) , 10 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , Ronard(4560) , eave antenna mount.
If the building has a chimney , install a , ronard(22120 , ronard(2218) , ronard(2224).
http://www.ronard.com.
The following information is important.
Connect a NEW Continues Length of RG-6 Coax that has the Compression type connectors on the ends of the coax , to the DB8e antenna and run the NEW Continues Length of Coax through a open door or window direct to 1 Tv.
No couplers
No ground block couplers
No splitters
No antenna system amplifier
No other devices
No etc.
The Tv Must Channel Scan for the , OTA=Over The Air , ATSC Digital Broadcast Tv Stations Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
DO NOT Channel Scan for Cable Tv Channels.
Digital Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.DoubleReScanAlert.pdf.
The tvfool report shows the Yellow and Pink reception zone channel list.
Starting at the top of the channel list , how far down the channel list are channels received??
Are the Yellow and Pink reception zone channels being received down the channel list to and including WMYS-LD MyNetwork??
