The two reports you've posted strongly suggest that mounting height may play a key role in your success or failure. It appears that the signal strength difference shifts toward favoring WFSB as you increase mounting height. Regardless, you'll still need as much forward gain as you can muster, while also supressing gain toward the rear. (A high F/B ratio.)
