Old 2-Sep-2014, 9:43 AM   #4
I recommend a -->2 Separate Antenna System.<--
With 1 Preamp , HDP-269.
And all Separate coaxes and devices to make up a 2 Separate antenna system.
Disconnect the preamp unit from the HD9095 UHF Antenna and aim the HD9095 antenna at about 131 degree magnetic compass direction.
The Tv Stations to the East South East are All Strong Signal Strength Tv Stations.
Install a , Antennas Direct , DB8e UHF antenna about 3 feet above the HD9095 UHF antenna.
Aim the , DB8e antenna at about 246 degree magnetic compass.
Connect the HDP-269 preamp to the , DB8e antenna.
The 2 Separate Antenna System coaxes and splitters and etc. will go to each location that you will like to have reception at.
A Tuner/Tuner Recorder will be at each location that you will have reception of the 2 Separate Antenna Systems.
The Tuner/Tuner Recorder is connected to 1 antenna system , the other antenna system is connected to the Tv.
The Tuner/Tuner Recorder is connected to a Tv input , HDMI or Component Video/Audio , or other input of the Tv.
http://www.epvision.com.
Is some effort to get the extra coaxes and splitter and device installed.
However , when is installed , Is Real Nice.
Makes it simple to change antennas.
You can start with 1 Tv location.
And then install the Separate Antenna System to other Tv locations at a later date.
