Old 1-Sep-2014, 10:38 PM   #4
Here Tuner/Tuner Recorders.
http://www.epvision.com.
A Simple reception situation that will receive -->Many<-->Digital Broadcast Tv Stations/Channels.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , South East , East , North.
Install a.
CM4228HD , UHF/VHF antenna aimed at about 120 degree magnetic direction.
Your reception location has receivable channels in the UHF band channels 14 thru 51 , and , VHF high band channels 7 thru 13.
The CM4228HD antenna is designed to receive channels in both Tv bands , receives channels 7 thru 51.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
As always , the Tv antenna aim direction and location can be adjusted for best reception.
To assist best reception , most Digital Tv's and Digital Tuners have a Signal Strength Meter and some Digital Tv's and Digital Tuners also have a Signal Quality Meter.
Here are some and not all above the roof antenna mounts.
http://www.ronard.com/909911.html. Install the , Ronard , 3 foot or 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , Ronard(4560) , eave antenna mount.
Home Depot has , 10 foot 6 inch length - 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe , the price is low at about 12 dollars.
The Top Rail Pipe can be cut to a shorter length.
Most antenna installations on the roof the antenna only needs to be as high as your head.
A antenna system amplifier will most likely not be required for reception at your reception location.
Buy at , http://www.hollandelectronics.com , or , http://www.amazon.com
For coax that is outside and exposed to Weather/Water , use RG-6 coax that has the Compression Type Connectors on the ends of the coax.
Do not use coax that has the crimp type connectors on the ends of the coax.
Snug tight all outside connections so as to keep Weather/Water out of outside connections and devices.
To make Double Sure Weather/Water does not get into outside connections wrap with.
http://www.coaxseal.com.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
For the Best Reliable Reception install the CM4228HD antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
The directions of reception at your location are , the main group of Tv transmitters to the , South East , East , and other transmitters to the North.
The Tv's Must Channel Scan for the , OTA=Over The Air , ATSC Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
DO NOT Channel Scan for Cable Tv Channels.
Last edited by teleview; 2-Sep-2014 at 5:32 AM. Reason: Clarify information and typos.
