Old 1-Sep-2014, 3:21 AM   #24
Charles
While continuing to browse through the forums, here at TVFool, I found several thread addressing the use of rotors. From the what I gleaned, one of the major drawbacks would be using a rotor with a tuner that does not offer the ability to manually add channels. Also, the problem of more than one television wanting to use the antenna at the same time with stations in different directions. Neither of these would be major drawbacks in our home so I am still quite interested in adding one to our setup. So I am still wanting to get some feedback regarding various makes and models.
The only other thing that I would appreciate help with is suggestions for the possible need of different antennas, and whether my reports at different heights suggest that I would make a worthwhile gain by mounting higher than 20 feet.
Charles
Charles is offline   Reply With Quote
