Old 31-Aug-2014, 7:33 PM   #4
I recommend a , Antennas Direct , DB8e , Current UHF channels 14 thru 51 antenna for reception of UHF channels.
To the North East at 52 degree magnetic compass direction a Tv Repeater/Translator , PBS Networks.
http://en.wikipedia.org/wiki/KTWU.
K30AL-D , Digital UHF channel 30.
To the South East at 149 degree magnetic compass direction a Tv Repeater/Translator , Unknown Network. Has been a Analog Tv transmitter.
Wikipedia says now owned by Luken Communications.
Contact Luken Communications engineering department and other departments , to discover what is being transmitted now.
http://en.wikipedia.org/wiki/K50JG.
K50JG , Analog ?? UHF channel 50.
Is interesting that , the Major Network Tv Stations or any other Tv Stations Networks of , Wichita , Joplin , Tulsa , Kansas City , are not leasing space on above listed towers.
Low Power Repeater Transmitters do not cost that much.
Is also interesting that space is not being leased on cell phone towers.
http://find.mapmuse.com/map/cell-tow...r/Fredonia,+KS.
Here are some above the roof antenna mounts for your reception location.
http://www.ronard.com/712.html. install the , ronard(712-50-10) , 10 foot tripod antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
Home Depot has , 10 foot 6 inch length - 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast pipe , the price is low at about 12 dollars.
Here are , Light Weight Aluminum , Free Standing , No Guy Wires , Lay Over Towers.
http://www.palcoelectronics.com/pe300.aspx.
Tvfool shows that a antenna height of 80 to 100 feet above ground will receive more long distance Tv stations.
Maximun height for towers is not 35 feet , the Tv antenna tower can be higher.
And a Tv antenna tower can be higher , requires no permit and lights.
At google maps , I see a tall tower North East of the intersection of , N.15th St and Madison.
And another tower at the intersection of , Polk St. and N. 6th St.
As you drive around the city limits of Fredonia and outside of the city limits of Fredonia , you will likely find more towers of different heights from short to tall.
Last edited by teleview; 1-Sep-2014 at 9:12 PM. Reason: Clarify information and typos.
