Another thing I would point out - of the powerful local stations, only WFAA 8 ABC will not be picked up by your UHF-only DB8e. I have not looked at your station lineup in detail, but you may not care about picking up more VHF stations than ch. 8. For example, KHFW-LD appears to be an evangelism station, which you may not care about. So, it may be possible to pick up Ch. 8 with a smaller antenna than the Y10713 - or perhaps you could mount a small antenna like the HBU11 on your building's chimney, and put the DB8e in the attic. But I wonder if you will get just as many stations from the HBU11 on the roof as you will see from the bigger antennas in the attic.
