You've spec'd a premium solution. The gain of those antennas is greater than some distribution amplifiers on the market. From what you've described, I anticipate no more than 16 dB total insertion loss at the highest frequency due to cable and splitter. At lower UHF and H-VHF frequencies the losses will be quite a bit less. If you have confirmed you have the space in your attic, or are willing to mount outdoors, this if 'plenty' of antenna. Their gain essentially negates all of you system losses.
