The provided tvfool report says resolved to block level only and the antenna height is 10 feet above ground.
So that a better recommendation for reception can be made.
Please make and post a tvfool report with the exact address and make the antenna height 25 feet above ground.
25 feet antenna height above ground is a Reference Antenna Height that provides a good evaluation of what can be received.
If the Exact address does not work to make the tvfool report.
Then go to the tvfool home page and click on >>Start MAPS<< .
Enter the zipcode for your location.
Click on (Map this) button.
Move the pointer to your exact location.
Make the antenna height in the report 25 feet above ground.
Click on the (Make Radar Plot) button.
Post the tvfool report , So a better recommendation can be made.
