Old 30-Aug-2014, 1:07 AM   #10
The Digital Broadcast Tv Stations/Channels are , Strong Signal Strength , Medium Signal Strength , Medium Low Signal Strength at your reception location.
The Tvfool channel list shows most Tv Stations are , LOS=Line of Sight at your reception location.
Line Of Sight is the best type of reception.
No hills or mountains to obstruct reception.
The tvfool radar plot shows the Real Channels that are Transmitted and Received.
And the tvfool Channel Columns List shows the , Real Channel Number.
And the (Virt) Virtual Number. The virtual number Is Not a Real Channel even if the virtual number is the same as the Real Channel.
-->TV Antennas Only Receive Real Channels.<--
The Current Real Tv Channels that are Transmitted and Received in the , USA , Canada , Mexico , are.
Current UHF band channels 14 thru 51.
The tvfool radar plot and channel list is not showing any receivable VHF low band channels 2 thru 6.
So a Tv antenna that is designed to receive VHF low band channels 2 thru 6 is not required.
The tvfool radar plot and channel list is showing receivable channels in the VHF high band and UHF band.
So a Tv antenna that is designed to receive Real Tv Channels in the VHF high band and UHF band will work OK.
The smaller a Tv antenna is , the less directional the Tv antenna is.
The bigger a Tv antenna is , the more directional the antenna is.
Most of the Tv Stations Reception is Strong Signal Strengths at your reception location.
A antenna system amplifier is not required at your reception location.
A antenna rotator is not required at your reception location.
The Digital Broadcast Tv Stations/Channels Will Be Received with a smaller antenna that is not very directional and will receive the Strong Signal Strength of/at All directions because the smaller antenna is not very directional and will receive the Strong Signal Strength Tv Stations Channels at , Front angles , Back angles , Back , of the smaller Tv antenna , Without Rotating the antenna.
The smaller antenna for reception is.
http://www.antennacraft.net.
HBU33 / VHF high band / UHF band antenna.
Aim the HBU33 antenna at about 325 degree magnetic compass direction for improved reception of the , Medium Low Signal Strength Tv Stations in the 325 degree direction and the other Stronger Signal Strength Tv Stations of other directions Will Be Received , With out a antenna rotator because the HBU33 antenna is not all that directional.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
To assist in the best reception , most Digital Tv's have a Signal Strenght Meter and some Digital Tv's also have a Signal Quality Meter.
A antenna system amplifier will not be required for , 1 , 2 , 3 , Tv's connected.
Here are some Above the Peak of the Roof antenna mounts.
http://www.ronard.com/909911.html. Install the 3 foot or 5 foot tripod antenna mount. 1 screw or bolt through each foot of the tripod antenna mount will be more the enough to hold tripod in place on the roof.
http://www.ronard.com/34424560.html. Instal the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
