Old 29-Aug-2014, 8:32 PM   #4
Install a.
http://www.antennacraft.net.
HBU11K antenna.
or
ANT751 antenna.
Different manufactures.
The HBU11K antenna has a slight edge of reception ability.
Aim the HBU11K or ANT751 at about 162 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
To assist the best reception , most Digital Tuners have a Signal Strength Meter and some Digital Tuners also have a Signal Quality Meter.
A antenna system amplifier is not required.
Install the antenna Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in All directions.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building , in the directions of reception.
At your reception location that is all directions.
