Thank you very much for all the replies. You've given me a lot of useful information. It seems the the majority of recommendations go into two camps.
One way to go is a major antenna like the Antennacraft HD1850, which seems to be an all-in-one solution with a Direct PA-18 Pre-Amp.
The second way to go is a two-antenna approach, utilizing the HD5030 if I can find it for VHF and the XG91 for UHF. I then connect both antennas to a tvpramp-1r preamp or RCA dual-input preamp and hopefully I have all my channels.
Is there a true benefit to going the multi-antenna route, or would getting a big antenna like the HD1850 really solve my problem? I'm no expert at this, but I am getting more knowledgeable as I read about these solutions. Thank you again for your help and I look forward to reading your responses.
