Old 29-Aug-2014, 3:31 AM   #4
I'd suggest that you run this test... http://forum.tvfool.com/showthread.php?t=13646
I'd use a new or known good matching transformer and new section of coax. The goal is to determine if the antenna is able to directly drive one tuner... If not. adjustments to aim and or mounting location/height will be the next step.
