Old 28-Aug-2014, 7:50 AM   #7
An online search for the manual was easy enough... The LT-37131A has the required ATSC capability that is needed for reception of over the air DTV signals. Have you set the antenna input to "Antenna" mode? (The default setting is 'Cable' which uses a different digital signal format.) And, have you scanned for channels?
That you saw a few channels makes me think you've already done this...
