Old 28-Aug-2014, 6:52 AM   #6
As a Test to prove reception.
Put a , Channel Master 4010 , indoor antenna.
In/at a 2nd floor , South West , West , facing window.
Aim the , CM4010 indoor antenna at about 235 degree magnetic compass direction.
Here is how to aim , indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Connect a NEW Continues Length of Coax to the CM4010 indoor antenna and run the NEW Continues Length of Coax , Through The Inside Of The House to the Flat Screen Tv.
http://www.summitsource.com.
Has the CM4010 , Summitsource part number , AN4010.
A antenna system amplifier is not required.
________________________________________________________________________
If you will like to bypass the indoor antenna test and install a antenna outside.
Above the Peak of the Roof install a.
http://www.channelmasterstore.com.
CM4228HD , UHF/VHF antenna aimed at about 235 degree magnetic compass direction.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
A antenna system amplifier is Not required.
Last edited by teleview; 31-Aug-2014 at 9:27 AM. Reason: Clarify information and typos.
