270 degree magnetic compass direction
Minimum 25' AGL
HBU-44 Antenna
Pre-Amp: Yes, same one already mentioned
You will recieve at least one of each tv network.
Antennaweb is way too conservative. I don't like that site. I recieve violet color code with strong signal stregnths indoors with a small bowtie or similar.
Aim away from obstructions. However, if there is one at the direction, move the antenna back a little bit or move around for best reception.
