Old 27-Aug-2014, 11:17 AM   #3
Stereocraig
You should not need an amplified antenna at your location.
It is probably being overdriven by strong signals.
Make sure your TV is set to antenna input, not cable, before you do a channel scan.
Your other TV does NOT need to be HD, it needs to have a digital tuner to work.
Every antenna ever made as far back as the dinosaurs, will be HDTV, digital and COLOR compatible.
The only thing a person needs to concern themselves with, is that it covers the bands that are available in a given area. (Real channels, not virtual)
