Old 27-Aug-2014, 2:51 AM   #7
Install a.
Antennas Direct , DB8e , Current UHF channels 14 thru 51 antenna.
http://www.amazon.com.
Aim the DB8e antenna at about 288 degree magnetic compass direction.
Install a.
Winegard , HD5030 , VHF channels 2 thru 13 antenna.
http://www.warrenelectronics.com.
Aim the HD5030 antenna at about 288 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antennas , do not trust a , cell phone , tablet and etc. compass.
To assist the best reception , most Digital Tv's have a Signal Strength Meter and Some Digital Tv's also have a Signal Quality Meter.
Install the , HD5030 antenna about 3+ feet below the DB8e antenna on the same antenna mast/pipe.
http://www.ronard.com/909911.html. Ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/712.html. Ronard(712-50-10) , 10 foot tripod antenna mount.
The tripod antenna mounts are moved around on the roof to find the location of best reception and then bolt the tripod antenna mount in place
Home Depot has , 10 foot 6 inch lengths , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe , the price is low at about 12 dollars.
A Antennas Direct , EU385CF , UVSJ=UHF/VHF - Separator/Joiner , can be used to connect the DB8e and HD5030 , together.
The DB8e UHF antenna is connected to the UHF connection of the UVSJ.
The HD5030 VHF antenna is connected to the VHF connection of the UVSJ.
The remaining connection of the UVSJ is connected to ,
Test antenna system amplifiers of your choices.
Last edited by teleview; 27-Aug-2014 at 6:43 PM. Reason: Clarify information and typos.
