Thread: Dallasproblems
Old 26-Aug-2014, 12:37 AM   #6
emartz91
A Clearstream 2-V is plenty of antenna. Aim it at 213 degrees magnetic compass direction. If the antenna is on the roof, you won't need an amp for at least 2-3 tv's. Those are very strong signals. I am quite jealous of your situation. Also try to be as far away from obstructions as far as you can such as trees or other buildings. You want line of sight so 25' above ground level is good to start. Good luck!
emartz91 is offline   Reply With Quote
