Thread: Dallasproblems
Old 26-Aug-2014, 12:13 AM   #4
The Signal Strengths are Very Strong at your reception location.
Do Not use or install any type or kind of antenna system amplifier.
Above the Peak of the Roof install a.
http://www.antennacraft.com.
AC9 antenna. http://www.antennacraft.net/pdfs/AC9.pdf.
Aim the AC9 antenna at about 230 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
To assist in obtaining the best reception Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/712.html. Install the , ronard(712-50-10) , 10 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe , the price is low at about 12 dollars.
A antenna system amplifier is Not required , do not use or install any type or kind of antenna system amplifier.
Avoid aiming the antenna into trees or any other obstructions in the directions of reception.
The directions of reception are , South West , South , West .
The tvfool radar map shows the Main Group of Tv Stations are to the South West.
To Prove Reception before connecting to a splitter and coaxes that are in/or on the house.
Connect a NEW Continues Length of Coax to the matching transformer (balun) connected to the AC9 antenna and run the NEW Continues Length of Coax through a open door or window - direct to 1 tv.
No couplers.
No ground block couplers.
No splitters.
No antenna system amplifiers.
No nothing.
Digital Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
Because the received Tv signal strengths are so strong at your reception location , a antenna system amplifier of any type or kind can make reception worse , because the amplifier will be over loaded because of the strong signal strengths.
1 , 2 , 3 , 4 , 5 , 6 , Tv's can be connected with a , 2 way , 3 way , 4 way , 6 way , splitter.
If reception drops to a low level when connecting the antenna to the coaxes and splitter , that are in or on the house.
Then you will be looking for , defective coax/s , defective connector/s , defective connection/s , defective splitter/s , defective device/s , defective etc/s. .
A way to discover defective/s is replace with new.
Disconnect and remove All satellite system components.
The antenna and antenna system Must Not be connected to any active part or parts of Cable Tv delivered services , Cable Tv service , Cable delivered internet service , Cable delivered phone service.
Cable delivered service/s Must Be On a Separate Coax.
Last edited by teleview; 28-Aug-2014 at 1:01 AM. Reason: Clarify information and typos.
