Old 25-Aug-2014, 11:17 PM   #5
The Current Broadcast Tv Stations/Channels that are being Transmitted and Received in the , USA , Canada , Mexico , are.
VHF high band channels , 7 thru 13.
Current UHF band channels 14 thru 51.
Your reception location has receivable Tv station channels in All 3 channel bands.
The Real channels column of the tvfool channel list and the radar plot map shows the Real channels that are transmitted and received.
The tvfool channel list also shows the (virt) virtual numbers.
Virtual numbers are Not Real Channels even if the virtual number is the same as the Real Channel.
Tv antennas receive Real Channels that are transmitted and received.
The Signal Strengths are Very Weak Signal Strengths at your reception location.
And in All 3 channel bands.
So a Big antenna is required to receive the Digital Broadcast Tv Stations/Channels.
Above the Peak of the Roof at no less then 25 feet above ground in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , North West.
Install a.
http://www.antennacraft.net.
HD1850 , All channel antenna.
Aim the HD1850 antenna at about 318 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Also to assist the best reception , most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Install a.
10G201 preamplifier.
Buy the , HFS-2D , HFS-3D , splitters at.
http://www.hollandelectronics.com. , or , http://www.amazon.com.
At no less then 25 feet above ground.
Here are Above the Peak of the Roof antenna mounts.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/712.html. Install the , ronard(712-50-10) , 10 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe , the price is low at about 12 dollars.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is install the antenna at a location that has the least amount to no amount of obstructions in the direction including your own , attic , roof , building .
The direction of reception is North West.
Last edited by teleview; 26-Aug-2014 at 2:51 AM. Reason: Clarify information and typos.
