Thanks for the replies. As I already mentioned in my original post, the only reason I added a splitter to the antenna was to make the antenna's attached coax cable longer so that I could test the reception in other areas of the living room. But, I didn't have much luck so I removed the splitter.
The coax cable attached to the antenna is only above 5 feet long, so I can't try sticking the antenna out a window. If I re-attach the splitter, I would be able to try that.
As I already mentioned, I am renting my house so I do not want an outdoor antenna since I don't know how much longer I will be living here. My landlord also put in the lease that he doesn't want anything mounted on the roof and I don't want to fight with him over it even if I could win.
I found a spot for the antenna where I can get CBS, FOX, and a couple other channels. That will be enough for football, so I may just leave everything as is for now. Especially if there are no other indoor antennas that could improve my signal. Thank you again for the help if there is no advice about indoor antennas.
