Old 25-Aug-2014, 6:55 PM   #2
It looks as if you'll need to use a large antenna such as the Winegard HD7084P, Antennacraft HD1850 or Channel Master CM-3020.
The path profiles of the signals from the NW show that you have rising terrain fairly close to your location. You'll need to take advantage of as much height as budget and safety allow. Before committing to a mounting location and drilling any holes, you'll want to verify reception.
Avoid aiming through trees and any part of nearby structures, including your own.
A high performance weak signal preamp such as the Antennas Direct PA-18 is indicated as well.
