You said money is tight.
1 UHF/VHF combination antenna , 1 Tv connected , No splitter .
The HBU44 antenna with no antenna system amplifier is the minimum size antenna I will recommend. A Antenna Craft , 10G201 preamplifier can be installed -If- required for reliable reception.
Notice that the word is -If- , not will be.
No , I will not recommend a smaller antenna.
No , I will not recommend a smaller antenna with or without a amplifier.
Reason: Clarify information and typos.
