Thread: day db8
Old 25-Aug-2014, 3:48 AM   #12
rhinoslim
Originally Posted by teleview View Post
For 1 Tv connected and 1 Antenna and No Antenna System Amplifier.
Install a.
http://www.antennacraft.net.
HBU44 , UHF/VHF antenna aimed at about 345 degree magnetic compass direction.
Okay. What would be the major difference from the HBU set up as opposed to the Y10-7-13 /DB8e set up you have mentioned.
Yes I do have a tree that is obstructing the signal I believe. It is on its way out so some branches here and there may not be a problem. Thanks again for the suggestions. Learning a lot here.
rhinoslim is offline   Reply With Quote
