Old 24-Aug-2014, 11:16 PM   #3
For Reliable Reception of the Local Digital Broadcast Tv Stations/Channels.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in All directions.
Install a.
http://www.antennacraft.net.
U2000 , Current UHF channels 14 thru 51 antenna.
Aim the U2000 antenna at about 270 degree magnetic compass direction. West.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Also to assist in obtaining the best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Strength Meter.
Here are some antenna mounts that will put the antenna above the roof.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/712.html. Install the , ronard(712-50-10) , 10 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , Ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diametter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe , the price is low at about 12 dollars.
For reception of the Local Digital Broadcast Tv Stations/Channels.
And Test for reception of the Long distance Digital Broadcast Tv Stations/Channels.
Do not install the U2000 antenna.
In place of the U2000 antenna install a.
HBU44 antenna.
Aim the HBU44 antenna at about 277 degree magnetic compass direction. West.
The Long distance Digital Broadcast Tv Stations/Channels in addition to the Locals that you will be looking for are.
WBTW-DT , Real VHF high band channel 13 , CBS and MyNetwork and Antenna Tv.
WPDE-DT , Real Current UHF band channel 16 , ABC.
WFXB-DT , Real Current UHF band channel 18. FOX and Me-Tv.
If the Long Distance Digital Broadcast Tv Stations/Channels are not Reliably Received with no antenna system amplifier then install a.
10G201 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Last edited by teleview; 25-Aug-2014 at 9:40 PM. Reason: Clarify information and typos.
