Thank You to both of you. This forum has been a lot of help.
From what I see on the test results of the test that I was informed about the signal is there, just being lost in either the addition of the 50' of coax or the Tivo itself. My guess would be the Tivo is sucking the signals dry with its four tuners. Would that be comparable to a four way splitter drain?
But I do have an idea. If the signal from Knoxville is to strong I will point the antenna at Chattanooga and just grab Knoxville on the back half. Maybe that will work?
It should come sometime Tuesday. If early enough I will set it up, if not I will do it on Wednesday and post the results.
Reason: spelling and missed typing a few words dern fat fingers
