Thread: day db8
Old 24-Aug-2014, 7:24 AM   #10
For 1 Tv connected and 1 Antenna and No Antenna System Amplifier.
Install a.
http://www.antennacraft.net.
HBU44 , UHF/VHF antenna aimed at about 345 degree magnetic compass direction.
Looking at the , Tvfool Radar Map and Channel List for the Current Plus Pending Applications Included Digital Broadcast Tv Stations/Channels.
Of the Tv Stations to the , North , North West.
You will be looking for reception in the Yellow and Pink reception zones , Down The Channel List to and including , WDCW , Real UHF band channel 50 , The CW Network.
You must make a effort to install the antenna at a location that has the least amount to no amount of obstructions in the directions of reception. North , North West.
The closer trees and other obstructions are to the receiving antenna in the directions of reception the more disrupted reception will be.
So how close is close??
If big tree/s is/are in your yard and the size of the yard is the typical size of a residential yard and the tree/s is/are blocking the reception of the antenna in the direction of reception. North , North West.
Then that is close.
You must avoid aiming the antenna or any antenna into close tree/s or other obstructions.
You can do this by locating the antenna at a location that is not blocked by close obstructions.
If the tree/s or some other obstruction to reception is/are in the neighbors yard on the other side of the yard further away from the receiving antenna , Then that is Better.
If the tree/s are further away , a block or more away , That is Better.
This final bit of information.
Because people freak out and do not install the antenna at all or do something really strange.
Yes you can Test reception at any location.
And Yes you can install the antenna above the chimney.
Last edited by teleview; 24-Aug-2014 at 8:35 PM. Reason: Clarify information and typos.
