Thread: day db8
Old 23-Aug-2014, 11:59 PM   #8
Above the Peak of the Roof in such a manner that the , attic , roof , building , are not , obstructing , impeding , blocking , reception in the directions of , North , North West , South West.
At no less then 25 feet above ground.
Install a , Antennas Direct , DB8e , Current UHF channels 14 thru 51 antenna.
http://www.amazon.com.
Aim 1 panel of the DB8e antenna at about 335 degree magnetic compass direction , aim the other panel at about 356 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antennas , do not trust a , cell phone , tablet and etc. compass.
Also to help with the Best reception , most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Also install a.
http://www.antennacraft.net.
Y10-7-13 , VHF high band channels 7 thru 13 antenna.
Install a.
10G221 preamplifier.
Connect the , DB8e , UHF antenna to the UHF connection of the 10G221 preamp.
Connect the , Y10-7-13 , VHF high band antenna to the VHF connection of the 10G221 preamp.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at. http://www.hollandelectronics.com. or . http://www.amazon.com.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.kyes.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
The following information is important.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building , in the directions of reception.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building , in the directions of reception. North , North West , South West.
Last edited by teleview; 24-Aug-2014 at 1:33 AM. Reason: Clarify information and typos.
