Buildings/houses that are wrapped with Stucko have stucko Wire wrapped around the house.
The wire holds the stucko in place and the wire is made of metal.
The Metal Net of Wire does a wonderful and fantastic job of reflecting Tv signals away so the Tv signals can not reach the Tv antenna in the house.
Also insulation panels that have a metal surface and wall panels that have metal surface do a wonderful and fantastic job of reflecting Tv signals away so the Tv signals can not get to the Tv antenna inside the house.
And so does metal roofs.
And metal doors.
Also bricks and rock walls do a great job of absorbing and blocking reception.
And so does tile roofs.
And so does concrete and concrete blocks.
Yes is important to install the Tv antenna at a location that the Tv signal can get to the Tv antenna.
Above the peak of the roof is a good place.
