Old 23-Aug-2014, 5:18 AM   #5
StephanieS
Yes, this was my thought too or a DB8e with a panel pointed at DC and a panel at pointed at Baltimore. Then a supplemental HBU11 for DC VHF support combined with a EU385CF.
Several ways to work it.
Originally Posted by stvcmty View Post
You are in a really good location for reception of both the DC and Baltimore markets.
I think teleview recommended the CM4228HD because it is usable on VHF. His list of steps are very well thought out.
I would add if you have any problems with reception for 7, 9, 11, or 13, VHF antenna(s) can be added to the CM4228HD. A Y10-7-13 pointed at DC, possibly angled to point over the trees would help with 7 and 9. A Y5-7-13 or a Y10-7-13 pointed at Baltimore would help with 11 and 13, again possibly angled to point over the trees. (VHF is nice, it will “bend” over obstacles better than UHF).
If you end up needing a VHF antenna for 7 and 9 and a VHF antenna for 11 and 13, merge the two with a channel 12 jointenna from the channel master store. http://www.channelmasterstore.com/JO..._p/cm-0582.htm Then merge the VHF signals from the jointenna with the CM4228HD using a UVSJ.
