Old 16-Dec-2010, 3:03 AM   #1
Buzzard
NW Atlanta (Acworth) Attic Install
First - great site, and great support on the boards!
I've ditched cable (except for high speed); HULU and Netflix are great, but I'd like to see local news and improve signal quality. I hope to lean on your expertise; I'm a newbie at this...
I will be installing in the attic of our 2 story home. Primarily interested in Network stations (ABC, CBS, FOX, & NBC). Will go to two TVs (main and computer).
There's a hill on the south side of house - while the hill is below the height of second story windows, a few trees stretch well above our roof from it.
TV Fool report:
http://www.tvfool.com/?option=com_wr...da3255f901c7a7
I'd rather error on the high-side when choosing the antenna, instead of having to upgrade later. Unless recommended otherwise, I will be reusing the coax from Satellite - which is ran from the attic to a "junction box" in our MBR closet. If it's best to split closer to the antenna, I believe there are actually two coax from satellite. Though, I'll need to then connect the two lines at the "junction box".
Advice on Antenna and associate hardware ("splitter", booster, amplifier or etc) would be appreciated. Also, if I need help with the install - what skillsets should I look for (general handyman - once I spec the HW; assuming using existing Coax?)
Many thanks in advance!
Buzzard is offline   Reply With Quote
