Old 23-Aug-2014, 1:13 AM   #25
Thinking in terms of.
I will get the highest gain amplifier I can get , and ram and slam the signal to the Tv's so I can get , All The Channels.
The Truth is , Is the way to get Less Channels.
Antenna System Amplifiers -->DO NOT<-->PULL The Signal From The Air and Antenna.
A antenna system amplifier will amplify what is received by the antenna.
But Does Not cause the antenna to suck signals out of the air.
Here is the Truth , the weaker the signal gets the larger the antenna gets to receive more signal.
Using a smaller antenna and a bigger amplifier , is the way to get less signal.
For your -->Current antenna setup of the HD Stacker<-- , use the lower gain ,
Antenna Craft 10G201 preamplifier or RCA TVPRAMP1R preamplifier.
Also know this.
Using a amplifier to ram and slam and force signal through , defective coax , defective connectors , defective connections , defective devices , defective etc. is a good way to get less reliable reception and more problems.
Last edited by teleview; 23-Aug-2014 at 3:48 PM. Reason: Clarify information and typos.
