Back to my grounding questions..................
On the side of the house closest to the antenna, there is an old ground rod that's been there for years. On the other side of the house closest to where the RG6 goes through the wall, that is where the Service Entrance is.
Can the antenna be grounded to the rod and the grounding block for the coax to the service entrance? That would be two grounding locations quite a distance apart. What's the problem by doing this if any?
