The Truth is.
Antennas are Beautiful and Handsome.
Know this.
Hiding antennas is a good way to get less reception.
Here is/are more facts and information.
As always , attics and the inside of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
The truth is.
The only way to discover if reliable reception will happen in the attic is to install a antenna in the attic.
The 1 advantage of the antenna in the attic , is the antenna will last a long time.
Most likely you are recommending the Antennacraft 5884 antenna because it is a All channel antenna that is designed to receive channels 2 thru 51.
Your reception location has receivable Tv channels in each of the 3 Tv channel bands.
The Current UHF band channels 14 thru 51.
And the 5884 antenna is available at a local store.
Yes the 5884 antenna is a very good antenna for reception at your location.
I am not saying that reception will be difficult with the ANT751 installed outside in the clear of obstructions.
Reason: Clarify information and typos.
