You're not facing a lot of strong signals. Still, I would avoid the 10G212 which is a deep fringe, weak signal design. If it overloads, you'll have destroyed the quality of the signals just received by the antenna.
Preamplifiers are not able to 'pull' signal from the air, antenna or coax... They only 'push' an amplified copy of the signal down the line. Amplifiers won't make a distorted or noisy signal better, because they are going to amplifier both the desired signal(s) and the distortion and noise.
I'd suggest the 10G201 or the RCA TVPRAMP1R.
