I think I will give this preamp a shot.
AntennaCraft 30dB High Gain TV/FM Mast-Mounted Amplifier 10G212
If that does not bring the signals up then I will replace the 50' run of coax since the 30' by itself did well.
The Tivo Roamio is known to suck down signals because of its four tuners. The customer service peeps on the phone even warned me about that before I even bought it.
I was not worried about those 80 marks as all stations took quite a tumble on the meter once the Tivo was hooked up. Two of the stations would not even come in once that happened.
Once I order and get the preamp, and get it set up I will post the results here.
