After the Testing of reception is done.
And more then 3 channels are received at this time of Testing and after the reception Testing is done.
(You said something about 45 channels).
A antenna system amplifier can be installed.
Install a.
http://www.antennacraft.net.
10G201 preamplifier.
And the Reception can also be Tested Without the antenna system amplifier.
When testing reception without the antenna system amplifier , All Parts of the amplifier must be disconnected and removed , Disconnect and remove the preamp unit , Disconnect and remove the power injector , Disconnect and remove the power supply.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
BHuy the , HFS-2D , HFS-3D , HFS-4D , splitters at ,
http://www.hollandelectronics.com , or ,
http://www.amazon.com.
Here is Clear and Simple Truth.
Antenna System Amplifiers are Not Used to Compensate For Or Ram Tv Signals
Through , Defective coax ,  Defective connectors , Defective connections ,
Defective devices , and other Defectives.
