This first one is directly to TV using just the 30' RG6 Quad with the Stacker now moved around back for testing. This is using the signal meter on the TV.
Antenna aimed at 45 degrees.
3.1 46-47
6.1 92-93
7.1 100
8.1 100
9.1 40-44
10.1 100
14.1 70-71
15.1 92
20.1 100
24.1 68
39.1 92-97
43.1 100
45.1 79-81
48.1 75-77
54.1 90-92
Here is what happened when I added the grounding block, 50' RG6 quad, and the Tivo Roamio (4 tuners) I had to use the Tivo signal meter, but same TV was used. The Tivo does show 0 signal if nothing is there
3.1 ----- no picture but Tivo meter showed 32 signal
6.1 70-72
7.1 72-80
8.1 70-72
9.1 ----- no picture but Tivo meter showed 32 signal
10.1 72-80
12.1 ---- no picture but Tivo meter showed 32 signal
14.1 35-36 lots of pixelation, unwatchable
15.1 65-67
20.1 70-72
24.1 45
39.1 ------ no picture - I have no idea what happened
43.1 70-72
45.1 ------ no picture but Tivo meter showed 32 signal
48.1 45
53.1 ------ no picture but Tivo meter showed 32 signal
54.1 70-72
61.1 ------ no picture but Tivo meter showed 32 signal
