Old 21-Aug-2014, 8:05 PM   #7
For reception of the , New Haven , Hartford , area , Digital Broadcast Tv Stations/Channels.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , block , by the , attic , roof , building , in the directions of , North East , East , South , South West.
Install a.
http://www.antennacraft.net.
HBU44 antenna.
Aim the HBU44 antenna at about , 52 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Most Digital Tv's have Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Install a , http://www.antennacraft.net.
10G201 preamplifier.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Install the HBU44 antenna at no less then 25 feet above ground.
Ronard antenna mounts are Over Built to Last a Long Time.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/712.html. Install the , ronard(712-50-10) , 10 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe , the price is low at about 12 dollars.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the , least amount to no amount of obstructions of any type or kind including your own , attic , roof , building , in the directions of reception.
The directions of reception at your location are , North East , East , South , South West.
Can also Test reception of the New York , Digital Broadcast Tv Stations/Channels.
Aim the HBU44 antenna at about 240 degree magnetic compass direction.
And Rescan for channels.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Channel Scan for the ATSC Digital Broadcast Tv Stations/channels.
DO NOT Channel Scan for Cable Tv Channels.
Last edited by teleview; 22-Aug-2014 at 7:29 AM. Reason: Clarify information and typos.
